Freelander Talk about the Land Rover Freelander within.
Rear door stuck shut
Old Mar 14, 2022 | 05:09 AM
joel4507's Avatar
Default Rear door stuck shut
Hi - new to Landrovers so some advice appreciated please. I have a 2004 Freelander td4 SE & the rear driver side door would not unlock on central locking however would lock. The door would only open from the inside but once opened from the inside it would also open from the outside until locked again. I have replaced the lock & the solenoid is now lifting the lock stick on unlocking & retracting on locking with the key fob but the door will not open. When I fitted the new lock it worked a couple of times with both inside & outside handles but no longer - some sort of mechanical failure? I have removed the door card & got my hand behind the lock & tried to move the catches I can reach but no success - door still stuck shut & now the cable has come off too - any ideas on how to get the door open please?
lazerbrains
LR2
Nov 17, 2017 11:07 AM
reddiscovery2
Nov 24, 2012 08:51 PM
EastCoastWarrior
May 9, 2011 08:54 PM
hersrud
Oct 13, 2010 04:41 PM
ctk111
Jun 11, 2010 01:44 PM
