Freelander Talk about the Land Rover Freelander within.
Reset radio code
Old Jan 1, 2018 | 06:56 AM
Faxdoc51's Avatar
Exclamation Reset radio code
hello can anyone help , I've a freelander 1 and the radio code needs re-setting ,
Problems, 1/ no code with the manual's 2/ no serial number on the radio ( been scratched off with removal by someone else)
So is there a procedure to clear the code & leave it without needing the code , or setting new code PLEASE...
Old Jan 1, 2018 | 08:38 PM
XCELLER8's Avatar
do you know if this is the original radio that came with the vehicle ??....my guess is that it isnt because the s/n has been removed....if it were original you could contact LR customer service and they will help.....in this case ...I dont know if they CAN help...you may be stuck with getting an aftermarket radio installed....or a used Rover unit with a S/N and hopefully a code....let us know how it goes
Old Jan 2, 2018 | 05:35 AM
Faxdoc51's Avatar
Smile radio code .
Thanks for the reply . seems I need a replacement radio , ho well I got it for free SO in the bin with it ,, cheers everybody..
Old Feb 27, 2018 | 08:59 AM
Martin Langwade's Avatar
Seems like a few people have had problems with the radio after battery disconnection . My batttery has been off and after looking for the code to put the radio back on I found a number written on the back . After trying this number in several configurations my radio now displays LOCKED . Seems the number we found was nothing to do with the radio but since then I have the code number from a note between the manual pages .
How do I get the LOCKED message off so that I can enter the code .
Cheers for any help .
Old Dec 11, 2023 | 08:30 PM
RapidRadioCodes's Avatar
4th Gear
A little late to help you Martin, but for anyone coming across this through Google as I did, the LOCKED message is displayed for a fix amount of time (usually 1 hour) that on some models increases with more incorrect attempts. You can find more detail and anything else you need to know about Land Rover radio codes via our Land Rover decoder here:
https://www.rapidradiocodes.co.uk/ma...ers/land-rover
We can generate most Land Rover radio codes, and all of the ones that we do generate are £4.99, making them far cheaper than most dealerships and other online services out there.
Roverboy3766
Nov 5, 2020 03:47 PM
kpl1228
Apr 7, 2011 08:00 PM
rsandmeyer
Dec 10, 2007 08:51 PM
billinohio
Jun 17, 2007 10:47 PM
ny1999
Mar 4, 2007 05:46 PM
