Freelander Talk about the Land Rover Freelander within.
Rough idle and driving, MAF sensor error
Old Nov 9, 2014 | 09:42 PM
Chimchase's Avatar
Exclamation Rough idle and driving, MAF sensor error
Greetings,
I have a 2002 Freelander s v6.
Every once in a while when I punched it I would get a hard hesitation and it would turn the service engine light on. Upon restarting the car it went away.
One day while going up hill and giving it a little more gas the engine sputtered and now continues to have a rough idle and drive. The engine light is now on for good.
I got the code 1472 along with other misfire codes. I changed the VIS motor, a suspected bad coil pack, fuel pump recall and some fuel injectors.
I still have the rough ride but not as much as before. I now receive only one code regarding the MAF Sensor. I cleaned the MAF sensor and it still has problems. BUT when I disconnect the MAF sensor there is no change in the way it runs. I would suspect it to run a little differently?
Any help would be super duper greatly appreciated! She has been sitting for a year and a half.
Old Aug 31, 2019 | 06:54 PM
Caprice Post's Avatar
Default Update
Did you get this fixed? I’m having the same problems.
Originally Posted by Chimchase
Greetings,
Old Sep 1, 2019 | 11:07 AM
Chimchase's Avatar
Default Update
Hi, I wasn’t able to resolve the issue. I believe the problem was internal and would cost a lot of money to replace all of the parts. I recommend finding a way to sell it unless you are in love with it. I’m sorry you are having this issue as well. Good luck!
mafiotulnr1
Dec 4, 2015 11:44 AM
MarineLandRover
Dec 6, 2013 04:51 PM
ripio31
Freelander
Sep 8, 2013 04:06 PM
Dimitri_g101
Freelander
Feb 5, 2010 01:07 PM
bowser881
Feb 2, 2009 01:30 PM
