Freelander Talk about the Land Rover Freelander within.
starting & other problems ...
Old Mar 17, 2009 | 06:25 AM
bertl's Avatar
4th Gear
Default starting & other problems ...
Hi all,
just joined this forum and feel so free to start with a request immediately
It's about my 2000 Freelander 1.8 - had some starting problems but after changing the crankshaft sensor it run well again, at least for a few days.
Since yesterday it does not start anymore, the starter motor is not running. The battery is charged fully, also you can hear the fuel injection working. But when turning the key nothing else happens.
Of course there could be several reasons for a non working starter (the starter motor itself, the wiring, the ECU, the immobilizer ...) but maybe it's a common and known issue with the freelander and someone has a hint what to look first??
And another quite strange problem - the window in the back door opens itself. Not when the car is running but when it is switched off completely after a few hours it goes down. It even shoudn't be electrified in that stage. Any ideas??
Thanks for your help and hints,
Rob
2000 Freelander 1.8 - 1997 Rover 216 Convertible - 1974 Rolls Royce Silver Shadow
Old Mar 18, 2009 | 12:48 PM
bertl's Avatar
4th Gear
Guys,
... that drives me nuts!
After a little hit with a hammer the starter motor works again, so apparently it needs just a little overhaul.
But guess what - of course the engine did not start, it doesn't fire now ...
Will have to check the crank sensor again, also several ignition parts probably.
It's so sad ...
Rob
DavidG
Dec 9, 2016 03:34 PM
pinkytoe69
Feb 27, 2013 05:17 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
