Freelander Talk about the Land Rover Freelander within.
strange freelander 1 noises from underneath
Old Mar 5, 2018 | 10:34 AM
badger's Avatar
Default strange freelander 1 noises from underneath
Hi so I had offside front ball joint and tyre replaced on my 05 freelander td4 and a few weeks later i noticed a whining noise even when my other half wasn't in the car.
It sounds like wind whistling through a house. It doesn't get faster or louder with speed and is still there when rolling in neutral.
Then shortly after I noticed a rumbling from the rear when at high speed. I corrected the low tyre pressures and it went away.
Now again shortly after I've noticed when manouvering at the end of a journey there's a distinct vibration/rumble from the mid rear when travelling in either direction at fullish lock.
It goes away quite quickly and isn't there at the start of a journey.
Are they connected? And should I be playing the lottery?
Thanks in advance for any help
Old Mar 5, 2018 | 10:39 AM
I would wonder if your VC in the driveline isn't going bad
Old Mar 5, 2018 | 10:42 AM
badger's Avatar
Was kinda hoping it might be something less expensive.
Can I just take the prop off and keep it 2wd?
Old Mar 5, 2018 | 11:40 PM
XCELLER8's Avatar
while you have the propshaft out...there are 2 carrier bearings and 3 u-joints that could be the culprit.....and yes on the lottery.....it does say "land rover "on the hood...lol
RossN99
Jan 24, 2018 10:37 PM
georgekler
Apr 10, 2008 10:00 PM
MichiganJim
Nov 30, 2007 07:42 PM
solihulldiscotruck
Apr 15, 2007 11:25 AM
Lancouver
Jul 14, 2006 01:22 PM
