Strange Noises when engine is under load
Old Jan 24, 2018 | 09:31 PM
RossN99's Avatar
Default Strange Noises when engine is under load
So I recently purchased a 2002 discovery and it appeared to have a bunch of issues such as overheating and other quirks upon purchasing. Since then I literally cannot get it to overheat and the only thing I've done is a coolant flush and changed the throttle body deicer, which had warped and would leak most of the coolant out. Anyways, so the car runs great but makes a few odd noises under some conditions. Most common noise occurs around 2k rpms and will stop when the rpms are dropped, but today I tested this while driving at around 50 mph and shifting into 3rd gear and keeping foot on the throttle. With the engine at over 2k and my foot on the gas the noise is still present, but when I took my foot off the gas the noise went away even though the rpms remained high. Would this imply its something in the drive train? If so I'm assuming my front driveshaft is on its way out. Is it possible for the driveshaft to make a few different sounds? A few different noises occur under similar conditions and I'm wondering if there is a connection. Sorry this is long winded, just trying to sort the truck out, thanks.
The noise is a squeaking noise that tends to get louder and higher pitched if rpms are increased after the noise starts. It comes and goes and sounds a little different each time.
Old Jan 24, 2018 | 09:33 PM
Alex_M's Avatar
I might've just missed it, but what does the noise sound like?
Old Jan 24, 2018 | 09:46 PM
RossN99's Avatar
Sorry I never put that in there I guess. Its a squeaking sound, not very high pitched, but sometimes it seems to have a faint knocking sound. To be honest it kind of changes from time to time which is what confuses me about it.
Old Jan 24, 2018 | 10:37 PM
Lisa Bunch's Avatar
Dang I thought this sounded familiar! There is a similar post, scroll down, "Squeaky noise when accelerating".
EstorilM
Mar 11, 2016 06:33 PM
colin2496
Dec 6, 2011 08:14 AM
specbiker
Aug 10, 2008 03:00 AM
askewm
Dec 23, 2006 11:03 PM
