Freelander Talk about the Land Rover Freelander within.
Td4 cam sensor
Old Jun 20, 2021 | 06:35 AM
Alloy's Avatar
Default Td4 cam sensor
I am trying to diagnose starting problem on my 2003 td4.
it’s a bit random and seems to be weather dependent. It will start with easy start.
Anyway I have done low pressure fuel pump and filter. Removed and cleaned injectors. Checked regulator o ring and seal and Replaced glow plugs. Not made anydifference.
So looking at voltage on cam sensor. With ignition on its 11.82v. Engine running it only drops to 11.6 ish. I think that indicatessensor might be dodgy. If I unplug completely the engine will not start at all so it’s clearly working to some extent.
Any thoughts?
Old Dec 3, 2021 | 02:14 PM
HopeItsNotAMoneyPit's Avatar
Disregard
djkaosone
Build Threads
Jun 3, 2021 09:10 AM
jtunio
Dec 11, 2020 03:13 AM
Chesley
Jun 28, 2019 11:34 PM
luxury1
Jan 29, 2008 10:14 PM
GodSavetheQueen
Jan 9, 2008 12:15 PM
