Freelander Talk about the Land Rover Freelander within.
Water spitting out the vents?
Old Dec 24, 2008 | 10:43 PM
2002 freebie se's Avatar
Default Water spitting out the vents?
I was driving in about 80 degree weather today, and I noticed water droplets spitting out of the vents in the center after about 30 minutes. Some shot out so fer it landed on my right bicep. This went on for about another 30 minutes. But then I noticed when I came to a stop, and especially when I turned, it sounded like there was water sloshing around inside the dash! If I made a hard enough turn, water sounded like it was "hissing," inside, and then I'd see vapor coming out of the vent.
Well, I parked in in the garage for about two hours and then I went to go on a two hour drive, and everything was fine. Also, when the sprinkling started, I unclicked the 'recirc' button, not knowing if this may have been the cause of the problem. It changed nothing, but as I said, after the two hour park, it went back to normal.
Thanks.
Old Dec 25, 2008 | 07:53 PM
rinmud's Avatar
Default RE: Water spitting out the vents?
The a/c condenser drain is bad you need to replace it with the improved one. Don't unplug it, replace it now, the radio and your ac relay will thank you for it... scott
Old Dec 25, 2008 | 09:02 PM
Thanks for the response, rinmud.
Is it something I can order from the dealer, and do myself?
Old Dec 26, 2008 | 12:47 AM
rinmud's Avatar
yes scott $16 bucks
Old Dec 26, 2008 | 06:19 AM
Thanks again for the info. I will get right on it!
brennan626
Aug 6, 2010 01:08 PM
Eak69
Apr 4, 2010 11:52 AM
4x4freak
Apr 11, 2007 09:48 PM
marco
Nov 19, 2006 07:03 AM
PAXPAY
Aug 16, 2006 12:26 AM
