00' Range Rover 4.6 Issues
Old Oct 14, 2009 | 06:27 PM
Jordanmd88's Avatar
Originally Posted by krazzz
How many miles are on it? I still don't get why you want to rebuild it over an oil leak? You said that the compression was good, leakdown was fine and that it runs well. Doesn't sound like an engine that needs a rebuild to me.
There are 130k on it.. And man the only reason I'm thinking about rebuilding it, is because it was almost ran dry of oil.. I
Even if it was for a min. The coating could have come off the bearing, I think i'm going to pop off a main cap or 2 and have a look. same with a rod bearing.. I need to do an Oil pan gasket anyways..
I'll Update when I've gotten into it, Probably not until this after this weekend, Deer season opens up this weekend
Old Oct 14, 2009 | 10:31 PM
krazzz's Avatar
I think you are probably going to be ok. If you had 3.5 quarts your sump never went dry and you should have had adequate pressure the whole time. I wouldn't be concerned unless she was doing a lot of high speed cornering or climbing incredibly steep inclines. Other than that it is unlikely that it ever ran dry. I'm not recommending that you run around intentionally with only 3.5 quarts but one time probably didn't hurt it. Now if you wife drives like I do you might have a problem.
Old Oct 25, 2009 | 06:47 PM
Jordanmd88's Avatar
Default Update.....
Finally got time to dig into this mess, thank god for having extra cars
It was really tough so far
Fan came right off * having the right tools is always great*
I put the Rover crank pulley holder on, and got out my big breaker bar..
after about 15 seconds of pressure on the breaker bar, one bolt snapped that holds the pulley holder tool on..
I guess I'm going to take the radiator out, and just put a impact on the crank bolt...
Old Oct 27, 2009 | 04:26 PM
Jordanmd88's Avatar
Ok Got everything off, yes the front seal was torn to pieces..
Got the broken bolt out of the Pulley
Put everything back together last night, Filled her up with water..
Started right up, had horrible lifter tick... It's sat for a little over 2 weeks now.. So I let the motor heat up and the lifter filled back up and she is running just fine now..
So all said and done for now, and the Mrs. is just going to drive it till the motor pops.. And I will just have one waiting to go in it..
Thanks for all your help
MLAWSO16
Feb 18, 2008 07:29 PM
ckwgreb77
Jan 31, 2008 09:29 AM
clacaria
Mar 18, 2007 03:26 PM
weigellj
Mar 28, 2006 11:51 PM
fidel309
Oct 9, 2005 03:41 AM
