Sponsored by: CARiD
03 Range Rover issues HDC and air suspension
Old Jan 31, 2008 | 08:29 AM
ckwgreb77's Avatar
Default 03 Range Rover issues HDC and air suspension
I have an '03 Range Rover which had the brakes replaced ata non-Land Rover shop. Since it has been in, the HDC and air suspension has been messed up. Whenever I make a right turn, or go over a bump in which the right side of the truck goes slightly higher than the rest of the truck, the HDC, air suspension and ABS become inactive. To fix this, I have to turn the car off, remove the key and wait for the truck to return to it's "neutral" height. When I start it again, it's fine until I make another turn or hit another bump.
Took the truck into a Land Rover dealer and they want to charge me $3000 to replace the ECM. I figured that the problem was just a sensor, but they are saying its not.....does this sound right to anyone?
Old Jan 31, 2008 | 09:29 AM
Default RE: 03 Range Rover issues HDC and air suspension
Did they tell you why? What tests did they run, what codes did they find? You need to know this before you can decide if it is fare or not.
Aulmeck
Feb 4, 2022 05:18 PM
TRIARII
Nov 5, 2013 01:37 PM
fastrx7man
Jan 28, 2012 12:49 PM
Nato
Jan 19, 2010 12:40 AM
devildog
Dec 24, 2008 06:02 AM
