01 range rover HSE techincal help
Old Oct 9, 2009 | 06:02 PM
afg's Avatar
afg
6th Gear
Default 01 range rover HSE techincal help
hi, guys new to the site, i bought a 01 hse 4.6L
few things cant figure out
the tempreture gage doesnt go up, their is still heat though??
the heated seats light up but it doesnt heat up?
and the srs some times comes on and goes off??
can any body help me please specify
thanks
Old Oct 9, 2009 | 07:23 PM
LRScott's Avatar
Temp sensor might be broken. A sure way to find out, is to hook up an obd scanner to it and see if the coolant temperature is reading appropriate temps. If it is, you have a gauge problem, if it does not or provides an inaccurate reading, you have a sensor problem. I recently had my temp sensor replaced, the part is only $20.
The heated seats probably do not work because the elements are worn out and broken. The repair is some what of a pain....
The SRS light coming on and off, is most likely due to the sensor under the seat being partially disconnected, I think it is a yellow connector. Just ensure it is fully connected.
Old Oct 11, 2009 | 10:25 PM
handsome rob's Avatar
The heated seats are very common not to work, they can be fixed but for many the hassle is just not worth it. Although I think about mine when it is 10* out and I need to go somewhere quickly.
Most of the issues in the Range Rover revolve around sensors, there are so many of them. First thingto always do is find where the sensor should be located and unplug it, see if there is any corrosion or gunk in there and then reconnect it. If you have some dielectric grease I would put some on as well.
Good luck with the issues and report back what you found out.
Old Nov 3, 2009 | 09:00 PM
afg's Avatar
afg
6th Gear
hi, guys thanks for the tips i figured out the problem with the temp gage
but the srs sensor cleared but still comes on if any body with any more saguestions
would be apprecated
Old Nov 3, 2009 | 09:03 PM
afg's Avatar
afg
6th Gear
Default 2001 range rover hse help
hi, guys i got 01 range rover hse the heated seats dont work light comes on but doesnt heat up? and the srs light comes on and go's off i tried unpluging the yeallow sensor clip in the bottom of seat didnt do anything
any suguestions??
thanks
Old Nov 3, 2009 | 09:04 PM
afg's Avatar
afg
6th Gear
would be apprecated
akondor
Mar 12, 2010 05:37 PM
Speed racer
Oct 11, 2008 10:56 PM
LBEJTA
Apr 23, 2007 09:55 PM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
Jim99
Oct 27, 2006 07:14 PM
