03 Rover Sagging on drivers side backend...???
![Thumbs down](https://landroverforums.com/forum/images/icons/icon13.gif)
Hi,
So my 03 range rover hse is sagging really low over the drivers side back tire. It is when I leave it in the garage for just a day or two and it's only that side over that one tire. What could this be...I hope it's not my EAS..
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
btw- It goes back to normal when I drive it and there are no error messages...
Well if you have just one side that will sag if sitting for a couple days then you probably have a leak in the bag. It will return to normal when driving but it may be running the comressor more than normal trying to keep it full. When it first starts it may be that bad but the compressor can run too much and then quit. I suggest getting under the truck and looking at the bags, look for cracks and small pin hole leaks. If you need a new one then replace them in pairs, try Arnott Springs for replacements, you can find them in their ebay store as well.
Ok thanks! Sorry if this sounds dumb but does this mean the EAS is going out? Everyone always says that's the biggest thing to watch out for in the Rover. Or is this just part of it? And is this something that a local shop could possibly do....is it easy? Or should the rover dealer do it?
Thanks for the help I am definately not mechanical...
-Sarah
-Sarah
spray down the right side bags to see a leak. if you see a leak then replace the bag. Arnott industries sells just the bag if you want it. And no coils in a Rover. Just airbags.
any shop can do the repair. its not bad. if the light stays on then go to the dealer to get it cleared but only if it stays on. In other words don't wait too long.
When you spray down the bags do it in all height positions. I had a bag that would leak only in one setting and not the others. They are really easy to replace especially on the back. If you buy from Arnott they will send instructions with the bags and they are easy to follow. It took me about 20 minutes to replace the bags on my 97'.
