03 RR- Camshaft position fault - help
Old Oct 24, 2008 | 09:28 PM
bhorwhat's Avatar
Default 03 RR- Camshaft position fault - help
About 6000 miles ago I had a Check Engine Light fault - "Camshaft position - Sensor A Bank 1 - Circuit response high" . I erased the code and now 5 months later its back. I reset this twice, but now it comes on and seems here to stay. No other performance issues with the engine that I notice.
Can anyone tell me what this means and possible solutions?
Thanks
Bob
Old Oct 25, 2008 | 12:09 AM
tacomatech's Avatar
Default RE: 03 RR- Camshaft position fault - help
I believe it means that the voltage signal from the cam position sensor to the engine ecu is higher than specified tolerances. Bank 1 is the bank on the right side as viewed from sitting in the driver's seat. The sensor is located on the front cylinder head. Check the wiring for corrosion, open/cut wires, and the like. Without being able to watch realtime display of the sensor reading, it is hard to diagnose. You could have a slack timing chain, faulty sensor or wiring issue. I would consider taking it in.
airisgood01
Mar 17, 2020 07:02 AM
Lee97Disco1
Feb 7, 2011 10:06 PM
icoolyou
May 23, 2007 08:52 AM
icoolyou
May 16, 2007 05:50 PM
