04 range rover/blower motor
Old Jul 19, 2011 | 03:07 PM
tracey's Avatar
4th Gear
Red face 04 range rover/blower motor
thanks for that answer and letting me know that there r two blower motors.my backseat blower blows great!its the front thats not blowing at all. would i need any special tools to change out the blower,besides flashlight, screwdriver.i c its in a tight spot under the dashboard.is there a youtube video that shows you how to change it out. i saw a video on bmw, changing of the blower motor.i believe it may be similar.or is there a website that shows you how to do it. im up for the challenge. i did change out the fuel injector on the truck,just was time consuming!!!!
Old Jul 21, 2011 | 08:25 PM
Rovin4life's Avatar
its the blower motor resistor that is is bad. Not the blower motor, to remove those which there are two you would need to pull the dash board and the entire hvac box.
but you can get to it by removing the fuse box and the two middle panels on the side of the transmission tunnel.
Old Jul 21, 2011 | 09:01 PM
Rovin4life's Avatar
so now the government wants you to have all your dignostics codes cleared for next year inspection. im so sick of the government getting in every aspect of my life. i have a oxygen sensor code that i have to have replaced by next year,$500dollars.can someone tell me what these codes are and what i need to have fixed: P0056ho2s heater control circuit bank 2 sensor 2......P1170 code.....P0160 O2 circuit sensor bank 2....P0159 O2 sensor circuit bank 2 sensor code....are the P0159 and P0160 the same oxygen code....and are there any cheaper sensors than the dealer>>>> and are they hard to replace?and where are they located?
Ok, first off if you have less then 110k on this truck then you probably had a bad cat that is causing the code cause its got a leak. Good news is if its under 110k you can get a new cat from the dealer. When they replace the cat if the oxygen sensor is frozen in then they will replace those frozen in. Good news though sometimes when all the sensors are frozen in they replace the cats under warrantee and you pay for the sensors. That way you don't come back next week with the same code and something else they have to fix. Be nice to the dealer and you might be surprised they might help you out on quite a bit.
jennywebb23
Mar 5, 2015 05:59 PM
dmonares
Aug 11, 2006 10:54 PM
willdisco99
Jul 9, 2006 12:59 PM
deejax
Jul 5, 2006 10:28 PM
eric2
May 28, 2005 02:44 AM
