'08 Range Rover Issues
Old Sep 25, 2013 | 12:35 PM
hardreign's Avatar
Default '08 Range Rover Issues
I have an '08 Range Rover with about 47,000 miles. I just had the brake pads and rotors replaced at the local dealership. The next day while commuting I was getting a strange humming sound that seemed to be originating from the driver's side front tire. It was not a grinding sound but a harmonic hum. It was only audible at low speeds during stop and go traffice on my commute. I brought it back to the dealer and they claimed it is the rear differential and unrelated to the brake work. They said the sound was referred and that's why it sounded like it was coming from the front of the car.
As I was driving back from dealer it was actually worse - it's louder and therefore I could hear it at higher speeds. The sound stops as soon as I touch the brakes. For example I was rolling through the parking lot, foot off the accelerator and there was a constant hum. I braked and the sound stopped. I released the brake and continued to roll and the sound started again.
Also, we had rain today - not sure if it's a coincidence or that contributed to it getting worse.
Thoughts?
Old Nov 17, 2013 | 01:28 PM
John in AZ's Avatar
5th Gear
OK, Im going to toss this out there because I had almost the identical same thing/noise. Mine was on the right front..... ended up being an axle shaft. For some reason the teeth shredded and I needed a new right front axle. Once replaced the problem was fixed.
Old Nov 23, 2013 | 07:55 AM
hardreign's Avatar
Thanks John. That seems like a more likely cause than anything I've been told. Neither repair shop was able to replicate the noise and it's since gone away. Not sure what to make of it.
MLAWSO16
Feb 18, 2008 07:29 PM
ckwgreb77
Jan 31, 2008 09:29 AM
clacaria
Mar 18, 2007 03:26 PM
weigellj
Mar 28, 2006 11:51 PM
fidel309
Oct 9, 2005 03:41 AM
