1992 Classic no power to Cigar lighters
Old Apr 30, 2008 | 02:45 PM
masher's Avatar
Default 1992 Classic no power to Cigar lighters
My 1992 Classic 3.9 has no power to the Cigar lighters, none of the fuses are blown.
I have had the binacle and lower dash off to try to trace the live feed wire back to see where the fault is but loose it behind the heater assembly.
I have various wiring diagrams up to 1990 all seem to use a different fuse! The feed wire is white with a yellow trace, all of the wiring diagrams I have found show the feed wire going back to the fuse box, but there are no white with yellow trace wires going to or from the fuse box, then going back and splicing off thelive feed (White) from the ignition when its switched on. I cannot find it!
Can anyone point me in the direction of the wiring diagram for RR Classic, in 1992 the Cigar lighter was relocated to the right hand side of the binacle, mine is on the laft so that would infer 1991 - 1992.
Regards
madmacanic
Sep 27, 2013 05:52 AM
seamonkey1
Mar 29, 2011 08:50 PM
hafool123
Nov 28, 2008 09:34 PM
hafool123
Off Topic
Nov 28, 2008 08:48 PM
Phototone
Audio/Visual Electronics
Apr 16, 2008 01:11 AM
