1996 4.0SE Starting Problem
Old Jul 19, 2006 | 06:30 PM
deejax's Avatar
5th Gear
Default 1996 4.0SE Starting Problem
I am unable to start my 1996 4.O SE. I eliminated any spark problem and suspect fuel delivery as I can't hear the fuel pump in the tank. If I spray fuel in the air intake manifold the engine starts. Checked the fuel relay - its ok. Is the fuel pump supposed to make any kind of noise while ignition is 'on'? for how long? I have since this morning eliminated the fuse, relay and (IFS) shut-off switch, located passanger side footwell. What pressure reading should I get on a pressure tester from the fuel pump? Thanks
Old Jul 19, 2006 | 06:41 PM
Default RE: 1996 4.0SE Starting Problem
Have you verified voltage at the pump? Do that first. The pump is designed to pump for a second or too, just long enough to get proper pressure to the engine and fire the cold start system then it shuts down till the engine starts.
Mike
Old Jul 19, 2006 | 10:45 PM
esaycho's Avatar
Should the pump only run for a second or two, or is it longer, My pump runs at least 10 seconds when i first switch it to on
Old Jul 20, 2006 | 02:10 AM
deejax's Avatar
5th Gear
Thanks for the suggestion. I checked the electric, it is OK. Earlier tonight I was able to start the car for few minutes, just enough time to read the fuel pressure at the rail of 36 PSI. But then I could not start it any more! Any ideas what the pressure shuld be at ?
1999SE40
Jun 1, 2014 08:05 PM
tomcat
Jul 8, 2006 01:27 PM
russwess
Feb 6, 2006 12:57 AM
mcanavan
Dec 9, 2004 05:42 PM
golfpro
Oct 18, 2004 04:50 PM
