1996 P38 4.6 "Service Engine Light"
Old Jun 12, 2011 | 06:43 AM
faversham's Avatar
Default 1996 P38 4.6 "Service Engine Light"
At 120,000 miles 'SERVICE ENGINE LIGHT" has gone on. Changed 02 sensors and Cats 40,000 miles ago. No errors come up w/ All-Data or OBD-2 scanners.
Is there any way to get rid of this error light? Thx.
Old Jun 13, 2011 | 08:04 PM
LRScott's Avatar
Yeah, take it out... It doesn't actually mean something is wrong. It is telling you to take it to the dealership to get the oil changed. In some cases you can get it to go away by disconnecting the battery for awhile. Many owners just take theirs out. If it is the "check engine" light, then you have a problem.
Old Jun 14, 2011 | 09:26 AM
faversham's Avatar
How do you remove the "Service Engine Light?" Is it on a single fuse?
Old Jun 14, 2011 | 01:18 PM
Ringo's Avatar
I assume he means to reach under the dash, twist the light socket out of the dash, remove the bulb and replace the socket. Cutting a wire to it would work too, but what happens if you cut the blue wire instead of the red?
Old Jun 14, 2011 | 01:31 PM
hilltoppersx's Avatar
whoa whoa whoa whoa.... don't go cutting wires or removing bulbs. It is an emissions maintenance reminder which is a function of the BECM and a normal odb2 reader isnt going to reset it.
sfortier99
Dec 28, 2019 11:35 AM
WaltNYC
Jun 9, 2011 10:08 AM
faversham
Apr 26, 2011 07:21 PM
salve7
Other
Nov 1, 2010 04:35 PM
kcferna
Jul 7, 2009 08:33 AM
