1999 Range Rover brake problms
Old Nov 30, 2012 | 01:31 PM
aroyal93's Avatar
Default 1999 Range Rover brake problms
I have a 1999 Range Rover. I changed the brake pads and bleed the bakes but it still does not stop. Does anyone have any ideas?
Old Nov 30, 2012 | 01:41 PM
krazzz's Avatar
Is this truck new to you or did it just start acting up? The reason I ask is that my brakes are fully functioning however it not a vehicle that I would brag about it's stopping abilities.
Old Dec 10, 2012 | 09:40 AM
wastedincome's Avatar
Is your brake pedal super hard???? Do you have abs, tc brake lights on cluster????
Old Dec 10, 2012 | 12:07 PM
04duxlr's Avatar
Really? The P38 I had stopped great. If you want brakes that suck try a D2.
As for the original post, have you checked the function of the pump, confirmed the accumulator is good and made sure the bleeding was done correctly? It is a bitch to do, but if you follow the steps in RAVE, it works well. Also, make sure that the fluid freely flows from the reservoir. There are little filter screens in there that clog up if the fluid isn't changed enough or if the wrong fluid is used. Cleaning them nearly impossible, but with lots brake cleaner and compressed air it can be done. Check here for more info: ABS Accumulator Replacement on a Range Rover 4.0/4.6/P38; abs
Old Dec 11, 2012 | 12:11 AM
krazzz's Avatar
I've had D1 & D2 and they stopped about the same as my P38. Of course I do have oversized tires which don't help. When I switch from my Rover to my Mercedes I almost put myself through the windshield the first couple times I stop until I get used to good brakes. lol
leddifer
Aug 18, 2010 08:14 PM
leddifer
May 22, 2010 05:42 PM
mgabriel
Feb 15, 2009 05:03 PM
mgabriel
Dec 8, 2008 02:33 AM
sky2you
Jun 19, 2007 08:44 PM
