2 or 3 Vent Pipe Fuel Tank
Old Aug 29, 2017 | 09:51 PM
FlamurAdili's Avatar
Default 2 or 3 Vent Pipe Fuel Tank
So, the fuel tank support plate on my '06 RRS is corroded to the point that it needs to be replaced. Apparently there are two styles of fuel pump/tank used from the factory. One with two vent pipes, the other three. Each one of these set ups uses a slightly different support plate. The retailer of the plate informs me that I need to contact the dealership with the VIN to find out which on the truck was built with. Obviously the dealership is not happy to disclose that information. Replacement is an easy DIY fix. I would rather not pay the dealership almost $700 to install a part I can obtain for under $200.
Any tips on how to figure out how many vents a tank has?
Old Aug 30, 2017 | 12:59 PM
OverRover's Avatar
Here's an idea, compare the tank plate on your truck to the pics above
Or call ANY LR Dealer's PARTS DEPT and give them your model info and ask for the tank support (as if you are going to BUY the part from them). And then they will ask for your VIN info and tell you the part you need. Good Luck!
Old Sep 4, 2017 | 07:20 PM
Why didn't I think of just looking underneath? I did and it does have the two bolts on the outboard side of the plate (*21G). Now I have a few days to run down the fuel in the tank to make it easier to support the tank. Looks like an easy procedure...just have to figure out how to support the tank while the plate is out.
Old Sep 4, 2017 | 08:20 PM
On your floor jack remove the jacking plate. It should leave you with a 1" hole.
Pick up a couple heavy fender washers, nut, and a 4" ish bolt (measure to find what works for you).
Than make a "H" out of 2x4 drill a hole in the center of the cross run the bolt through with the washers and tighten it up. One home made tank support, that can lift and lower.
Also works for trannys, transfer cases, axel housings etc
Travelor
Dec 4, 2022 09:51 PM
geek_IM
Mar 31, 2018 03:03 PM
photo2u
Oct 13, 2014 04:02 PM
JustTani
Oct 9, 2014 01:42 PM
Landzu
Sep 13, 2008 11:32 AM
