2003 Range Rover rear disc removal
Old Oct 19, 2011 | 03:10 PM
gzman's Avatar
3rd Gear
Default 2003 Range Rover rear disc removal
Help ! I'm trying to replace brake pads and rotors on all 4 corners. Front pad & rotor replacement was painless. However I'm having a hard time removing the rear rotors. Is there some trick or tip that I am missing? Could the emergency brake be engaged and preventing me from removing? I've tried heating and hitting with a hammer. Nothing. Thanks for your help.......
Old Oct 19, 2011 | 09:28 PM
Greggles's Avatar
I believe there is a allen bolt that needs to be removed. It's in peep hole in the hat?
Old Oct 19, 2011 | 09:34 PM
see attached for page from RAVE manual - similar
File Type: pdf
Old Oct 24, 2011 | 10:41 AM
gzman's Avatar
3rd Gear
Actually, everyone left out a key element in the process. You need to orient the parking brake adjustment hole in the rear to about 6 o'clock, pop out the plastic cap, insert a flat blade screwdriver, and adjust the parking brake to release any tension. Once you release this pressure, the rotor assembly will pop right off.... with a few whacks of a good sized mallot I might add. I also used a flywheel puller on the rotor to apply a wee bit of pressure. Good luck.
Old Oct 24, 2011 | 01:37 PM
socalrovershop's Avatar
you shouldnt have to do this process since the rotor is actually run down. and if you do this you will have to readjust the entire parking brake system after doing so.
Old Oct 25, 2011 | 08:24 AM
gzman's Avatar
3rd Gear
Gotcha..... Thanks for the info.
Old Oct 25, 2011 | 09:47 AM
Mrmerlin's Avatar
make sure to readjust the E brakes after fitting the new rotor
euronavdiscs
Feb 6, 2016 03:41 PM
2001RR4.6
Off Topic
Jan 2, 2013 01:00 AM
whiski runner
Aug 6, 2012 05:43 PM
gregstil7
Jan 16, 2010 04:16 PM
sailorcolin
Oct 29, 2008 04:41 PM
