2004 Range Rover HSE Transfer Case L-H Switch
Old Jan 3, 2007 | 12:03 PM
smokinwheels's Avatar
7th Gear
Default 2004 Range Rover HSE Transfer Case L-H Switch
I am a new rover owner. I have a 2004 Range Rover HSE. I was trying to get it into Low gearing but it wont. I read the manual which says that put the gear selector in N and then pull the transfer switch (located to the right of the gear) backwards and release, a low gear light will flash in the instrument cluster and once engaged will stay illuminated. Nothing is happening for me... no flashing and no illumination... i dont even feel any difference in driving characteristic, it seems like the low gear is not engaging... can anyone help me with this... i hope this is not a major transmission or transfer case overhaul job ... the car drives amazingly otherwise with no issues whatsoever ... i am hoping it is a blown fuse or just a bad switch ... has anyone experienced this?... your expert help will be appreciated ... thanks
Old Jan 3, 2007 | 03:03 PM
Default RE: 2004 Range Rover HSE Transfer Case L-H Switch
You need to get a test probe and starting checking power down to the solenoid that activates the low range shifter.
I doubt you have an expensive$$$$ problem.
Mike
Old Jan 4, 2007 | 12:56 PM
7th Gear
It is under factory warranty so I will be taking it to the dealer ... will let you know what the issue was.
Old Jan 4, 2007 | 01:01 PM
7th Gear
i know it cannot be an expensive issue ... the car drives like a dream otherwise ... does that solenoid also control information presented on the instrument cluster display because there is no indication there as well for the L-H range transfer...i only wish they used more expensive material for the interior .. i used to drive an X5 4.4 before this and I see a differnce in quality.
Old Dec 28, 2010 | 09:09 PM
storm09's Avatar
I have a 2004 range rover and may transmission went out. I need a soleniod kit for my transmission. Anyone have any idea were to get one?
shawnjkelley
Feb 1, 2012 10:24 AM
dcarr1971
Jan 27, 2012 10:31 AM
ColeRover
Feb 9, 2011 07:05 AM
yonniecarrizo
Dec 30, 2008 06:06 PM
DerrickInMississippi
Jan 12, 2008 07:49 AM
