2004 Range Rover HSE won't start
Old Apr 28, 2011 | 02:05 PM
Edgarts's Avatar
Default 2004 Range Rover HSE won't start
I tried starting my 2004 range rover hse last week, it didn't start. There was no noise coming from the starter. After few tries i heard one click sound. I never had a problem with the starting before. I checked all the fuses, the battery is new and i could tell it wasn't from the battary. I decided to take the starter out. I removed the cover which was over the starter. I decided to give it a last try before i take the starter out. To my surprise it started. The first few starts sounded wird but then just started fine. I tried since then it starts just fine, but i am afraid to drive the car since it might do it again an with hot weather in California i don't want to be stock on the road. I also want to add that while i took the cover the out i did touch the wire that goes to the starter. Could it be weak connection?
Old Apr 28, 2011 | 11:22 PM
LRScott's Avatar
The relay or starter could be going bad. I would replace the relay since its cheap and see if the problem continues. It could be a weak connection like you said, but generally it will at least try to start vs. just one click. One click screams relay to me...
Old Apr 29, 2011 | 10:43 AM
Edgarts's Avatar
Where is the relay located?
Old Apr 29, 2011 | 12:45 PM
LRScott's Avatar
Good question, refer to your owner's manual lol. Sorry don't know where it is on the L322. On mine it is with the fuses in the engine compartment.
Old Apr 29, 2011 | 05:28 PM
Edgarts's Avatar
I checked the owner manual it says only dealer is authorized to replays the relays. there are few relays but doesn't say what it is for.
Old Apr 29, 2011 | 06:51 PM
LRScott's Avatar
You might find downloading this to be beneficial: http://www.yourwebdesigns.com/rave02.iso
Its the service manual for your rover. The P38 is in there too I believe. It might take some digging, but anything you need to know about the rover is in there. You will have to burn it to a disc. Please hurry with the download, they are shutting down this server in a couple of days. Once its gone its gone.
Old Apr 30, 2011 | 02:03 PM
Edgarts's Avatar
thanks.
Edgarts
Nov 29, 2024 07:53 AM
budge96
Oct 26, 2013 04:44 PM
wenb1018
Jul 7, 2013 06:17 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
Edgarts
Apr 27, 2011 11:08 AM
