04 Range Rover Hse cooling pressure build up
Old Apr 28, 2011 | 02:23 PM
Edgarts's Avatar
Default 04 Range Rover Hse cooling pressure build up
Few months ago while I was driving, I realised that the water gauge pasted the 1/2 mark and it's close to 3/4 but has not reached the red line. I pulled over quick.Checked and found out the cooling plastic bottle cracked and it caused the car to overheat. I replaced the bottle and tested and seemed at the time everything was ok. The next day when I was driving i realized it was passing the 1/2 mark. I pulled over again and noticed that small hose that goes on the back of the head was busted. I replaced the hose and talk to mechanic who works on rovers. He told me that these engines even thought that i didn't overheat all the way to red the head gasket goes bad and there might be a pressure build up in your cooling system. He told me to check the cooling to see if there is pressure. I opened the cap few times and i realized that there was pressure in there. I was ready to take the head out. Drove after that few times and seems the problem went away. I checked the cooling and seems to me that there is no pressure, plus no hose problems. What do you guys think happpened and am I ok to take a long trip with the car? I am afraid to drive the car for too long. Forgot to add that each time i changed a part i took the air out from the cooling system so there was no air in the system. An after all this engine runs great and no check engine light.
Old Apr 28, 2011 | 11:19 PM
LRScott's Avatar
If you did not severely overheat the engine, you are probably ok. The mechanic might be mixing the BMW and Rover V8 up. The rover v8 does not take overheating very well. The BMW engine (yours) is a more rugged motor and should be fine so long as it wasn't red lined for an extended period of time. How many miles are on it and when was the cooling system last serviced? If you are 100k or close to it, you might need to start replacing the radiator, hoses, thermostat, water pump, etc. Another thing, the cooling systems on rovers are pressurized, they are supposed to be. Over pressurization can be caused by many things, including the head gaskets. However, I would test other components before ripping the engine apart.
Old Apr 29, 2011 | 10:50 AM
Edgarts's Avatar
I am only at 55k and I had to replaced the radiator a year ago due to and accident, but I have not changed the termostat and the water pump. Do you think I should change them?
Old Apr 29, 2011 | 12:42 PM
LRScott's Avatar
I would have a pressure test done first to verify if it is over pressurizing before replacing anything. I would also pull some of the spark plugs and drain the oil to check for any signs of coolant. Is the rover consuming any coolant?
Old Apr 29, 2011 | 05:31 PM
Edgarts's Avatar
no coolant stays the same level and no trace of coolant in the oil.
Old Apr 29, 2011 | 06:45 PM
LRScott's Avatar
You still need to have it pressure tested to see what pressure the cooling system is running at. If its running to high, your gaskets are probably in need of replacement. The crack in the reservoir and blown hose could be due to old age, but you won't know until you pressure test it.
Old Apr 30, 2011 | 02:05 PM
Edgarts's Avatar
thanks. I will let you know what i find out
Sleek Motoring
Build Threads
15
Mar 19, 2015 03:20 AM
gribur
Mar 6, 2015 08:38 PM
dsmtrain
Jun 1, 2008 03:37 PM
jkeving
Apr 11, 2007 11:27 PM
ambishop
Audio/Visual Electronics
Dec 13, 2006 04:58 PM
