2006 Range Rover air suspension
Old Mar 29, 2013 | 01:08 PM
robbing's Avatar
4wd High
Default 2006 Range Rover air suspension
I have a 2006 Rover that has a leak in the front drivers side air suspension. I can raise the vehicle and hear and feel the air coming out of it.
I've ordered a replacement from Arnott but I started wondering. If I have a whole in the front driver side would that cause the whole Rover to lower or just that front left corner? I guess I don't know if the whole system is connected so the air from the other bags can get out if there are any leaks.
Thank you for your help.
Old Mar 31, 2013 | 08:34 PM
LR Techniker's Avatar
The suspension system periodically wakes up to monitor the suspension. If one level sensor is lower than the others, it will lower the other three corners to keep it level. This is why most times, you have to disconnect the battery over night to see which corner is leaking, as this prevents the "wake up" cycle.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
jmcmurra
Dec 7, 2012 04:26 PM
fastrx7man
Jan 28, 2012 12:49 PM
tripz
Jan 4, 2007 05:58 PM
