2008 RRS Height problem!!!!!!!!
Old Feb 8, 2017 | 08:14 PM
Rangeroversport08's Avatar
Default 2008 RRS Height problem!!!!!!!!
hello Land Rover people I have a 2008 Hse Range Rover sport has 100,xxx miles .. I've noticed the passenger side sits lower then the driver side I have no codes or any faults doesn't lose air height stays the same just the driver side sits higher then passenger .. I have brand new struts the whole assembly all around I've read it could be a faulty ride height sensor .. any help would be appreciated
Old Feb 10, 2017 | 05:47 AM
LR Techniker's Avatar
Start by getting the suspension calibrated. This procedure "should" be done every time a suspension component is replaced, but it rarely does.
The procedure requires a diagnostic computer to perform, so you will have to take it to a competent shop (somebody that specializes in Land Rover) or dealer. It also requires the vehicle to be raised and lowered several times, so hopefully your compressor is in good shape.
huladaddy
Jan 15, 2017 11:51 AM
starcraft1
Jan 26, 2016 11:30 AM
gillart
Mar 6, 2015 07:14 AM
jdelace
Dec 23, 2010 05:33 PM
ankuse
Nov 14, 2010 10:07 PM
