2016 Range Rover Diesel Sport Low Pressure AC Port location
Old Jun 2, 2021 | 01:19 PM
Ymha02's Avatar
5th Gear
Default 2016 Range Rover Diesel Sport Low Pressure AC Port location
Hello,
I am new to the Land Rover Range Rover world. I am trying to locate the low pressure ac port so I can recharge my wife’s car with Freon. However, I am stuck thinking I found it and then not. There is no label like I am used to on another car that says low pressure or L or anything like that. I found two lines on the drive side near the wall with ports on them. One of the ports is on a like that is thicker than the other so I assumed that was it. I tried to see if I can fit my charger connector on that, it realized maybe I should stop and ask first! . The compressor looks like it kicks on properly. Did a find the low pressure line or is it hiding somewhere such as under the car, in the compartment somewhere.
I am trying to avoid a few hundred dollars for someone to look at it.
Old Aug 10, 2021 | 04:49 PM
Dplax00's Avatar
[QUOTE=Ymha02;776776]
Hello,
I am trying to avoid a few hundred dollars for someone to look at it.[/QUOTE
did you figure this out?]
Old Aug 12, 2021 | 07:58 AM
Ymha02's Avatar
5th Gear
Default Update
Turns out I was using the wrong type of connector and cooling agent.
I had to go buy a 1234yf refrigerant that came with a 1234yf connector.
the high side(fatter pipe) is the one for the low pressure. Basically it’s the one the fit the 1234yf connector and then I followed directions on the 1234yf bottle to refill my car.
ljdiscovery
Oct 23, 2020 01:46 PM
jimvw57
Jul 18, 2017 12:15 AM
samfb24
LR2
Mar 20, 2016 04:55 PM
LR3BB
Oct 16, 2015 06:19 AM
ngarover
Aug 12, 2010 05:38 PM
