4.6 P38 Cooling system Nightmare
Hi all, appoligies if you've seen this before but just after as much help as I can get hence posting on quite a few forums.
I have a cooling system nightmare, I am not ruling out the fault of a slipped liner (although the engines only done 34k) but I would like to see if any one elce thinks theres another reason, I have the following problems;
- Water loss, some times I worse than others.
- High pressure in the cooling hoses.
- The bottom of the rad is stone cold, feeling the rad when it's upto temp it gets progresively colder as I work my way down and if I flush it through with a hose it seem to have plenty of flow and I have changed the thermostat.
- And possably totaly unrelated but the interior heaters give out no heat untill I am moving.
- I have not as yet pressure tested the cylinders.
- I have no power loss
- Oil is fine no level change.
Thanks in advance for any help.
Going to have the Rad off at the weekend because a couple of people have suggested that the cause may well lye there.
RE: 4.6 P38 Cooling system Nightmare
Vaccum tested the system to -24psi with an air lift kit eariler and the pressure held for 20 mins with absolutly no drop in the vaccum, refilled the cooling system through the airllift kit and ran it on my drive for about 30 mins, with no loss of coolant, took the truck out for a 10 mile drive and lost ½ the fluid from the header tank.
This is getting annoying. now.
Savannah Buzz
04-16-2012 04:21 PM
RROJ
07-24-2011 07:59 AM
Evian
12-11-2006 10:54 PM
