92 classic timing advance question
Old Jan 27, 2016 | 10:30 PM
mmaesner's Avatar
Default 92 classic timing advance question
So my 92 has been having an intermittent problem with the engine cutting out or missing at 2000 rpm and above under load. It does not happen all the time it will work fine for a day or two then come back. When the problem first came up I put in a new coil and that seemed to fix as it ran great for a couple of weeks. In my mind it would seem to be either timing advance issue or vacuum issue. Anybody have suggestions on how I could test the timing advance.
Or any other suggestions appreciated
Old Jan 28, 2016 | 06:08 AM
drowssap's Avatar
apply vacuum to the advance with a hand pump, i use a pump from a blood pressure pump.
you can also use a timing light
Old Jan 29, 2016 | 09:05 AM
Shiftonthefly1's Avatar
Assuming your truck is up to date on its maintenance, I'd do like Drowning said and take cap off and check for advance movement. Check the vacation line incoming.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
Beatrover20th
Jan 24, 2013 02:19 AM
chavhater
Jan 6, 2013 07:38 AM
dodge_mich
Apr 22, 2008 02:28 PM
