96 Range Rover DSE
Old Feb 18, 2005 | 12:43 PM
les mitchell's Avatar
4th Gear
Default 96 Range Rover DSE
hi,
my range rover has a problem starting when its HOT
any ideas would be a great help!!!!!!!
Old Feb 18, 2005 | 03:53 PM
Lighting90's Avatar
Default RE: 96 Range Rover DSE
How is it when you try to start when hot?
Does it make any noises, clicking etc,? Does it turn the engine over but just doesn't start?
Does it start but die again striaght away?
A bit more discription of noises and sounds when you try would help to give a better idea of things to look for..
Old Feb 18, 2005 | 04:05 PM
4th Gear
ORIGINAL: Lighting90
the engine turns over normal , no extra noises always starts but winds over for atleast anything up to 30 secs.
even if u stop for fuel for a short time it still doesnt start straight away
Old Feb 20, 2005 | 05:47 AM
Lighting90's Avatar
Have you noticed any drop in performance of your engine at all.. just thinking of a fuel problem, i.e. a pump issue or injectors blocked or not spraying as they should due to wear.
Old Feb 21, 2005 | 02:52 PM
4th Gear
well it cant be the injecters as it doesnt smoke like that, and we dont think it is the pump.
no drop in performance at all
Old May 23, 2008 | 02:27 AM
Anteater's Avatar
3rd Gear
I've got the same issue with a '96 4.6 HSE. Why would the fuel pump be in question if it only battles with a hot start up?
Old May 23, 2008 | 02:35 AM
polar's Avatar
It could be "leaky injectors" dumping fuel into the cylinders while off and flooding the engine. I have seen this on Early fuel injected engines.
The only way I know is to look for a small puff "if you will" of black smoke after the start, sootie substace in the tail pipe,or a decrease in fuel economy.
Old May 23, 2008 | 02:42 AM
Anteater's Avatar
3rd Gear
Fastest response time on the planet, thnx Polar. Will have a look. There has been a decrease in economy.
One test we did was to disconnect the fuel pipe to gauge the amount that came through on cranking - there was an initial spurt followed by drought. Is this norm or does it point towards the fuel pump?
Old May 29, 2008 | 04:25 AM
Anteater's Avatar
3rd Gear
Just an update - found a decent 2nd hand pump and replaced mine - driving beautifully! Feul consumption is great as well... ;-)
Off Topic
Dec 15, 2009 07:17 PM
marog
Oct 4, 2007 01:49 AM
balaurus
Apr 28, 2006 10:14 AM
20cj
Nov 6, 2005 06:02 PM
aldenplanthire
Jan 22, 2005 08:15 AM
