96 Range Rover no low range
Hello everyone,
I am new to the forum and new to Land Rover ownership. I am having a problem with my 96 4.0 SE. When I move the H shifter into low range, the vehicle stays in high range. The dash lights still indicate high range, and everything works as it should in high range. I removed the center console and locatedthe micro switch on the shifter that engages in low range. I tested the micro switch and it works fine, however there is no voltage at the wires feeding the microswitch. I have tried to figure out where this switch gets its voltage from, but after hours of reading and tracing wires, I can't figure it out. The switch has 2 wires going to it. 1 is blue and the other is yellow. Neither has voltage with the vehicle running. Could someone please help me shed some light on this problem.
Thank you,
Wilson
Thank you,
Wilson
nboulle
Jan 6, 2014 09:00 PM
nboulle
Jan 6, 2014 08:58 PM
mwyoung
Nov 2, 2011 12:28 PM
Skimino Farms
Jul 30, 2011 07:47 AM
Classic89
Aug 10, 2007 08:58 PM
