Occasional Difficulty Shifting from High Range to Low Range
Old Sep 6, 2011 | 10:38 AM
mwyoung's Avatar
Default Occasional Difficulty Shifting from High Range to Low Range
Hello,
My transfer case is having some odd behavior, and I'm wondering/hoping that someone else has encountered the same issue.
When I first hop in the truck, or after it's been sitting for 10-20 minutes, I can easily shift from high range to low range. The effort required is about the same weather I'm at a stop or slowly rolling.
On the other hand, if the truck has been rolling for a while it can be very difficult, nearly impossible, to shift to low range. If I shake the lever, roll back and forth, and generally fiddle with the lever it will usually pop into low range with slightly more force than is generally required.
Once engaged it seems to go in and out of gear just fine for the duration of a trail ride. It's really just a hassle when I first arrive at the trail head or after cruising easy forest roads in high-range between trails.
I recently changed the fluid and the problem remains.
I'm thinking something is seizing when it gets hot or that there is some issue with the driveline being under excess tension after lengthly driving. I could be wrong on both accounts.
Any thoughts are appreciated.
Thanks,
Old Sep 6, 2011 | 06:19 PM
sloppyjoe's Avatar
you gotta lube the linkage. get a flashlight and peer up above the t-case and you will see the shifter linkage and cable. you gotta lube that linkage. wd-40 will work but it will cook off after a few weeks as A LOT of heat hits it with the exhaust being so close. a good coating of heavy duty chain wax works well for months. if you can get at it with a good grease that might be best. i just give it a shot of chain wax every 3 months when i am doing general futsing around like tightening bolts, cleaning, checking for things in need of attention etc.
also only shift into low on gravel,sand, etc. dont do it on pavement as it can mess up the driveline. cheers!
Old Sep 6, 2011 | 06:31 PM
lordmorpheus's Avatar
I think you are thinking about the differential lock (if equipped). Low gear can be selected on pavement, if what you are trying to pull necessitates it. You just cannot go very fast when in low range.
Old Sep 6, 2011 | 07:28 PM
sloppyjoe's Avatar
i know what i was thinking even though i didnt say it right
Old Sep 6, 2011 | 07:58 PM
That's what I thought you were thinking, I think.
Old Sep 6, 2011 | 08:02 PM
sloppyjoe's Avatar
now im not so sure
Old Sep 8, 2011 | 11:37 AM
mwyoung's Avatar
An update. Someone suggested that I try applying fresh grease to my propellor/slip shafts. I'm going to give that a shot this weekend and will report the results.
Old Nov 2, 2011 | 12:28 PM
mwyoung's Avatar
A long overdue update. I completely lubed the entire drive-line (u-joints and propellor shafts). Shifting the transfer case is much smoother now. I've also taken to regularly lubricating the linkage - thanks for the reminder Sloppyjoe!
omarica7
Mar 11, 2014 08:12 AM
Shibby
Sep 26, 2012 10:03 AM
Street Wolf
Sep 6, 2011 04:15 AM
sidinseattle
Jul 16, 2010 10:21 PM
EATMAN
Nov 10, 2006 12:15 AM
