97 range rover not starting
Yes I tried a jump start and still nothing. I'm not getting a crank at all. I believe it's the starter. How can I check this out? Where is the starter? When I turn the key I'm not getting fuel to the rail line. Could this be due to not enough juice getting to the pump? J may try to jump start again. I should still be getting fuel to the rail line even with a bad starter, correct?
Well if the starter is not turning the motor then it is not receiving signals to send the fuel to keep trying to start the truck. If you tap the starter then it may work since it can go out some times and work others. Usually you should have had some sort of idea that it was going out just by listening to it.
I am not sure what the issue is but checking out the starter would be first after the battery, could be a bad connection somewhere so just start tracing the wires.
Webbiz Innovations
10-18-2012 07:50 PM
umoms
04-03-2008 06:22 PM
