Sponsored by: CARiD
01 Rover 4.6 Not Starting Need Help ASAP!
Old Oct 17, 2012 | 09:46 PM
Webbiz Innovations's Avatar
4th Gear
Exclamation 01 Rover 4.6 Not Starting Need Help ASAP!
Hello
Thanks for looking and trying to help
I have a 2001 Range Rover 4.6 and it has some starting issues::
1: Sometimes it starts, sometimes it does not--Always cranks
2. Usually the non starting takes place when cold or in the mornings
3. I replaced fuel pump with aftermarket fuel pump--Ran fine for 5 days now its back to starting when it feels like starting.
4. Run Great all day today, but who knows what lies ahead for me in the AM.
5. This problem has been off and on for about 3 weeks.
6. On another note, if I spray starting fluid when not starting it will fire but dies back out. Wait a few hours and it starts and runs lie new.
I have read a ton of posts that say Cam Sensor and Im looking for some good educated guesses....Mine are Bad Cam sensor--Defective Fuel Pump
Thanks Guys I really Appreciate the Help!!
Old Oct 17, 2012 | 09:49 PM
Bad crank position sensor, the cam sensor never fails on these things.
Old Oct 17, 2012 | 09:52 PM
4th Gear
So the crank position sensor would cause the above issues? Rule out defective fuel pump? Also Do local auto stores stock the sensor?
Thanks
Old Oct 18, 2012 | 07:50 PM
Yes the local parts store can order you a new crank sensor.
I re-read your thread, it ran fine for a week with the new fuel pump, so either the fuel pump went bad or you did something wrong.
If it runs on the starter fluid then you have spark and that rules out the crank sensor.
Did you install a whole new fuel pump assembly or did you just replace the electric motor?
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
edisons disco2
LR2
Aug 21, 2008 03:10 PM
Disbet
Jan 6, 2008 11:41 AM
Brad S1
Jun 28, 2006 03:25 PM
TATZOO
Aug 28, 2005 10:16 PM
