rover not starting
Old Aug 21, 2013 | 11:03 PM
country_8769's Avatar
Default rover not starting
I have a 1999 discovery 2, I was headed to work the other day and it just died. stopped on the road door dinger was working doom lights on. can't roll Windows up. turn the key on no dash lights, nothin. stuck in p ark. need some help....ignition? maybe I don't know.
Old Aug 21, 2013 | 11:17 PM
ralphobell's Avatar
Have you checked the voltage on the Battery?
Old Aug 22, 2013 | 12:28 AM
Before you jump start it, be sure to hold down the hood alarm switch. Alarm does not like to be awakened, and can immobilize vehicle. If alternator is weak, it won't charge battery enough and you will basically exhaust the reserve minutes of the battery and everything electric stops. Across the battery terminals, when at idle, should be13.8-14.4 volts. 13.2 absolute minumum when truck is running or you are not charging the battery.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
Webbiz Innovations
Oct 18, 2012 07:50 PM
Roverfix97
Jun 9, 2010 10:29 PM
Gary N
Jun 13, 2009 02:19 PM
nick
Freelander
Mar 14, 2006 04:41 PM
