98 Rover BCeM odd but huge problem
Old Jun 16, 2009 | 09:53 PM
98bluerangerover's Avatar
Default 98 Rover BCeM odd but huge problem
so i rolled all the windows down in the garage one day, the next day i get in and the battery is dead. i charged the battery up and then the RR window wouldnt roll up. so i let it go for the day. then the battery died again and then i charged it and it said fuse #22 i think the RR window and heated seats, was blown. so i put another 30 amp in and it blew, so after finding out the RR window motor was so hot i couldnt touch it(shorting out). so i unplug the door and put a 30 amp in and it works. i was replacing the motor and charging the battery again and then i smell something burning up. hear to find out the BCeM is smoking. so i unhook it all take this apart and here to find out the 4 relays are melted and tosted the wires too. so was the cause to this that window motor shorting out and not blowing the fuse right away or what? i would like to but a new BCeM but i dont want that to melt the relays again. i am stuck with a broken Rover what should i do? i am new to this site. thank you to who ever can help me with my problem
Old Jun 16, 2009 | 10:45 PM
skyguy's Avatar
what state are you in? There is a rover mech here in IL that could help you. Glenn @ therovershopinc.com
Old Jun 17, 2009 | 05:51 PM
Smile glen
i am located in NE iowa, thank you very much for the connection
brad
Old Jun 17, 2009 | 09:32 PM
LRScott's Avatar
Well, if your BECM was smoking then it is toast. Anytime any sort of computer smokes it is gone and needs to be replaced (whether with cars or desktop PCs). You are likely to find a used one on ebay for a descent price or on roverparts for something outrageous. As a precaution I would also replace the fuse box and the window motor as a precautionary measure unless you can get the motor to work else where without any issues and you open up the fuse box and see ABSOLUTELY nothing wrong.
elpapisf
Apr 15, 2012 10:19 AM
moomoo
May 23, 2011 05:22 AM
paris1099
Sep 26, 2010 01:47 PM
mrossipir
Jun 8, 2009 07:15 AM
nofoofoo
Nov 14, 2008 08:41 AM
