99 Range Rover EAS faults
Old Sep 7, 2008 | 09:46 PM
mgabriel's Avatar
Default 99 Range Rover EAS faults
Hey guys....
I have a 99 Range Rover which had problems with the EAS system some months ago. The air springs are good and would inflate, but there is a problem with the compressor or something else. I installed a fix by bypassing the complete EAS system, but of course can't control the hight any more because I have to manually put air in the springs. I am fine with this but the EAS fault Max speed 35 MPH, or something to that effect stays on my control panel all the time. I don't have access to my fuel, milage and other stats and would like to know if I can clear the faults and keep them off since I am not using the EAS without some sort of adapter or fault reader. Is this possible and if so how???
Thanks in advance....
Michael
Old Sep 8, 2008 | 09:09 AM
raid13's Avatar
Default RE: 99 Range Rover EAS faults
i have been installing a lot of spring conversion kits lately. not as nice of a ride as air
but you will never have another EAS problem. thay even come in 1" and 2" lifts too.
Old Sep 8, 2008 | 10:36 AM
mgabriel's Avatar
I have been contimplating switching to a conversion. I am very interested in coil springs with the 2" lift, but do enjoy the ride of the air springs. My plans are to use them as long as they stay inflated. Don't you have to deal with disabling the EAS when you convert to coil springs or do you just install a fault module of some sort?
Thanks again,
Michael
Old Sep 8, 2008 | 03:58 PM
raid13's Avatar
there is an over ride box that plugs into the becm tricking the eas system in to Manuel mode.
http://www.roverparts.com/Parts/9520LBHD.cfm
all so suggest replacing the shocks at this point because you have
to unbolt the lower half of the shocks to installed the spring kit.
http://www.roverparts.com/Parts/9720.cfm
i think old man emu makes the best shocks with that spring kit.
Old Mar 30, 2011 | 12:31 PM
ukinvestigation's Avatar
Default overide box
Land Rover Air Suspension To Coil Spring Conversion Kit - Atlantic British
Shock Kit - Front & Rear - Old Man Emu / ARB for Range Rover 4.0 (P38), Steering & Suspension Parts
where can i get an overide box for my 1997 range rover.
i have springs fitted, but have 2max speed 35mph " on the dash..... how can i remover it ?
sety
Aug 20, 2014 08:45 PM
brooksa
Dec 21, 2010 06:01 PM
TYoung
Freelander
Aug 17, 2010 04:19 AM
lipadj46
Jun 12, 2009 12:04 PM
simjack
Oct 12, 2008 10:24 AM
