'99 RR fires and runs, but no move...
Old Sep 23, 2008 | 04:54 PM
nathan214's Avatar
6th Gear
Default '99 RR fires and runs, but no move...
My '99 RR was having running issues and the dealer said it was the ecu. Well i ordered another ecu and replaced it with that...but now the RR wont move. It will fire and run but when put into gear nothing happens. I can put the old ecu back in and the problem continues. Any help would be great
Thanks Nate
Old Sep 26, 2008 | 06:12 AM
ptschram's Avatar
Default RE: '99 RR fires and runs, but no move...
Which ECU did you replace? Engine, transmission? Any messages on the instrument panel display, like oh, maybe "Gearbox Fault"?
It's not uncommon for the gearbox selector switch to fail on these trucks, I've replaced many of them.
Old Oct 14, 2008 | 07:54 PM
nathan214's Avatar
6th Gear
I replaced the engine ecu, but ended up putting the original back in...the only thing it displays is EAS Fault. When I try and put it in park i can hear what I assume is the parking pod grinding. So I shut it off in neutral, then put it in park. I can then get out and push it back and forth like it was in neutral. So this leads me to think its transmission related...?
Old Oct 14, 2008 | 10:52 PM
tacomatech's Avatar
Check faults in the auto gearbox ecu. Then post what faults there are, if any.
Old Oct 20, 2008 | 11:08 AM
nathan214's Avatar
6th Gear
I go about doing this how exactly?
Old Oct 20, 2008 | 11:36 PM
tacomatech's Avatar
Take it to the dealer.
Old Oct 21, 2008 | 06:02 PM
nathan214's Avatar
6th Gear
Yea I figured, but thats kind of hard to do when it doesnt move and the dealer is an hour and a half away...
Old Oct 21, 2008 | 06:21 PM
nathan214's Avatar
6th Gear
Possible selector issues? It baffles me because I drove it into our shop with no problems. Opened the bonnett replaced the original engine ecu with the new one and this problem occured. So I then put the original ecu back in and this problem still occured...The vehicle has not been offroad, bottomed out, or hit anything or had anything hit underneath to break anything, so I dont know why this would happen all of a sudden.
Caz Brookes
Oct 30, 2012 06:16 PM
giboulou13
Nov 1, 2010 07:37 AM
tacomatech
Oct 22, 2008 10:08 PM
janikphoto
Defender
Mar 14, 2008 01:11 PM
