About to buy a 2011 Range Rover sport
Old May 3, 2016 | 05:14 PM
starcraft1's Avatar
Default About to buy a 2011 Range Rover sport
Hello all,
I am about to buy a 2011 RRS. The price is right for $29,900 being it is equipt with the LUX package and has 52,000 miles on it. Just wanted to see if there are any common issues I should look into. I have done extensive research on the 2006-2009 edition as that was the one I wanted before I found this one. Thise seem to be remarkably reliable for rovers (I have had a disco 2 for the last 12 years so I know how these trucks operate) and there is a lot of help on the web regarding them. However, when you get to the next generation (2010-2013) there isn't much out there. Don't know if this is a good or bad thing or whether rover fixed any of the common problems like the control arms, suspension issues, Etc. Want to make sure I look into all possible things before I pull the trigger. Any help will be appreciated
Old Jun 23, 2016 | 10:14 PM
Ada2016's Avatar
4wd High
Default I suggest you I get a good used engine
If you bought the RR with a blown head gaskets, chances are there might be many more other issues related to it. Unless you get the work done with warranty or take a trip to the stealership
Good luck
ibkent
Oct 25, 2015 10:20 PM
djson2k8
Appearance & Camping Set Ups
Sep 5, 2015 10:01 AM
socalrover
Mar 23, 2014 08:40 PM
asmithcash4real
ROAMING WITH FRIENDS
Jul 4, 2011 07:27 PM
Vincent@CEC
May 5, 2011 05:56 PM
