ABS comes on whenever I brake
Old May 2, 2008 | 12:56 PM
Roveroh's Avatar
Default ABS comes on whenever I brake
Even when I am sitting in park. When I first start the car, it will run for about 15/20 sec then shut-off, but everytime I depress the brake petal, it runs for about 1/2 secs.
Bad pump? Bad Accumulator?
Any thoughts would be helpful.
ETA 1996 RR 4.0
Old May 12, 2008 | 08:15 PM
jwb1266's Avatar
Default RE: ABS comes on whenever I brake
Any Luck, I have the same problem on a 92 classic?
Old May 12, 2008 | 09:44 PM
roverguy7's Avatar
bad accumulator, not holding a reservoir of the press you need. as for the classic, too old for me man, but pretty sure it has the same basic setup, but its an expensive guess there... roveroh, you need to see if you have a good pedal on the first press after it srops running, if so, its the accum., if not, youre looking at other issues too
LADEROUTE
Mar 12, 2014 08:58 PM
marlymarl
Apr 21, 2012 12:49 PM
cipher982
Dec 13, 2011 07:50 PM
vishrb
Nov 19, 2010 12:09 PM
VikingDiesel
Mar 10, 2009 11:35 PM
