AC Fault
Old Jul 1, 2005 | 11:11 AM
VB_Rover's Avatar
Default AC Fault
The AC fault light (the opened book with the exclamation point) came on last night in my Rover. I looked this up in the owners manual and it just told me to head over to the dealer. Any ideas on what is triggering this fault? Has anyone else had it triggered? Should I rush over to my dealer or can I drive with it in its fault condition? Thanks for any help!
Old May 3, 2006 | 12:32 AM
IconDrummer's Avatar
5th Gear
Default RE: AC Fault
I am having this same problem I know it was a year ago but did you find out what the issue was?
Old May 6, 2006 | 12:39 PM
rinmud's Avatar
need t-4 to find out probably best case senerio heater core temp senser maybe a cooked relay in master panel or worst a blend door motor. Good news the light goes out as soon as its fixed check the relays first any sign of a barbeque burt or brown buy a new one in the master relay panel in the engine bay
Old May 9, 2006 | 01:46 PM
By summer when things get hot you will want to have the dealer check it out cause you will probably be getting a little warm.
Mike
Old Sep 30, 2006 | 10:23 PM
artcareer's Avatar
here's a cool little article to diagnose whast the meaning of the BOOK ! is
http://www.rangie.com/articles_model...d=72&modelId=2
Old Oct 1, 2006 | 12:20 PM
slackwaresupport's Avatar
mine is the same, but i think i figured mine out.. the drivers side will not blow hot air and the passengers will..
Old Nov 12, 2006 | 09:33 PM
artcareer's Avatar
that's exactly what mine is doing...dealer says replace ATC Control Unit and left and center acentuater doors...how about you?
06Range
May 8, 2013 09:01 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
anhernandez
Aug 18, 2009 12:47 AM
