Actual Temperature Gauge and where to put one on 4.2L Engine
Old Jun 8, 2012 | 03:12 PM
juanrover's Avatar
Default Actual Temperature Gauge and where to put one on 4.2L Engine
Since the 1995 4.2L range rover doesn't have the ability to OBDII like UltraGauge, is there a vacant port on the engine to put a coolant temperature gauge, i.e. one that reads in degree...not like the idiot one on dash? Or do I have to sacrifice the dash sensor and will that mess up something related to the ECU?
Old Jun 13, 2012 | 12:25 PM
drowssap's Avatar
install this in your upper hose and you can run whatever gauge you wish.
32 MM or 1 1/4 Inch Water Sender Attachment
Old Jun 14, 2012 | 01:59 PM
juanrover's Avatar
Thumbs up Sweet inline flow ....
Thanks....I will. I discovered this item yesterday as well...in the racing equipment market...now I'm a hot rod? 4.2L and kick'in....and knock'in a bit too.
ImQuattro
Mar 15, 2014 09:21 PM
nigelf63
Freelander
Jun 19, 2012 02:41 PM
honda50r
Dec 14, 2011 09:06 PM
1961 Lincoln
Feb 1, 2010 12:49 PM
