adding transmission fluid
on
Same tranny as a D2 I believe, if so you have to check, fill and drain the fluid thru the fill plug and or drain plug.
Start the engine when cold, shift to drive then reverse, then leave it running in park, crawl under and pull the fill plug from the tranny pan, if no fluid comes out, then add. If fluif starts to come out put the plug back in ASAP and you are set.
LRScott
03-04-2009 08:39 AM
