adding transmission fluid
Old Nov 30, 2007 | 02:26 PM
bobbydave's Avatar
Default adding transmission fluid
i maybe blind but i cant find the stick to check the transmission level on my 1999 4.6 RR
Old Dec 1, 2007 | 10:43 AM
Default RE: adding transmission fluid
Same tranny as a D2 I believe, if so you have to check, fill and drain the fluid thru the fill plug and or drain plug.
Start the engine when cold, shift to drive then reverse, then leave it running in park, crawl under and pull the fill plug from the tranny pan, if no fluid comes out, then add. If fluif starts to come out put the plug back in ASAP and you are set.
Old Dec 1, 2007 | 03:46 PM
cptshanman's Avatar
DiscoMike, funny this post came up because I was going to add a post similar. The transmission is almost done in my D2. What is the "fill procedure" for an empty transmission?
Thanks!
Shannon
Old Dec 2, 2007 | 08:42 AM
So you are saying that you had your's rebuilt or replaced??
If so, fill the pan, start the engine, go to drive and then reverse, turn of the tranny and repeat till you get your 10.3 quarts back in it.
Old Dec 2, 2007 | 02:47 PM
cptshanman's Avatar
Yepper, I got that used transmission with 46k miles on it...should be back on the road by tomorrow afternoon!
Shannon
Athana
Jun 8, 2019 10:23 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
aknewbie
Freelander
Apr 26, 2009 03:26 PM
LRScott
Mar 4, 2009 08:39 AM
bobbydave
Dec 4, 2007 05:45 PM
