alternator belt issues
Old Apr 21, 2010 | 11:44 AM
diverdad69's Avatar
8th Gear
Default alternator belt issues
well i keep loosing alternator belts, i put on a new alternator, thinking it might be the power steering pump as i get a bit of squeeling now and then, last belt lasted a week then this AM done!!! does anyone know of a rebiuild kit for the power steering pump? bearings etc? i have a 92 RRC
thanks
Sean
Old Apr 21, 2010 | 09:12 PM
LRScott's Avatar
Are you sure its the pump? Does it turn smoothly? It might be your tensioner pulley that is causing this. I would check to ensure it is giving the correct tension and that the pulley wheel turns smooth too. Check the other components, turn them to see if they are smooth and don't have any noticeable creaks or binding.
Old Apr 22, 2010 | 08:35 AM
diverdad69's Avatar
8th Gear
well the only tensioner pulleys i have are on the AC compressor side and between the water pump and crankshaft. i have a small v belt between the pump and the alternator. what i did find yesterday is that i believe the IDIOT i bought this rig from put transmission fluid into the power steering pump reservoir as i found red fluid in there, i dont ever recall red power steering fluid??? i think i need to drain it and refill. my pullys were out of line by 1/16 of an ionch, not huge but sometimes thats enough. nowi have a hesitation around 50mph, check engine light is on, thinking its the o2 senso it will seem like it wants to die then off she goes again. cleaned the MAS yesterday, didnt help. and can i say WTF about this wiring issue.
Old Apr 22, 2010 | 08:40 PM
RRC's use transmission fluid in the power steering, so the idiot put the correct fluid in there.
Dexron III to be exact, same as your transmission.
Old Apr 23, 2010 | 08:50 AM
diverdad69's Avatar
8th Gear
LOL spike thank you for putting me in my place, cant tell ive never owned a rover before can you..... thanks for the reply
GLW52
Jan 6, 2014 09:56 AM
DiscoRover007
Jan 17, 2012 12:34 PM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
joshsrover
Apr 2, 2008 11:03 AM
