Alternator Wiring and Dual Batteries for 90 RRC
Old Jul 2, 2007 | 08:11 PM
kjj0506's Avatar
Default Alternator Wiring and Dual Batteries for 90 RRC
Any one have any advice for wiring or accessory upgrades for adding a higher amperage alternator ?
I have a nice Powermaster 130 amp small GM alternator and would like to add it as well as a second battery for accessories ( I may add a solar Trickle charger as well for the RV battery ) . Any pics , diagrams , advice will be appreciated greatly .
Old Sep 3, 2007 | 01:51 PM
Bleacho's Avatar
Default RE: Alternator Wiring and Dual Batteries for 90 RRC
No need for the extra alternator really,
that is unless you are REALLY going to be sucking some juice for a massively demandingpurpose!,
How about wiring up a split charge relay (approx £8-£14) to your existing alternator.
(preferably the 85 amp unitor higher anyway).
Depending on your engine bay setup, if like mine, do as I did & make space in engine bay by making a small bracket & move the power steering fluid reservoir toward the alternator slightly, insert your deep cycle or leisure battery in the vacant battery position ( check air filter box for clearance ) if it fouls, replace with a Universal K&N style air filter (making sure it is the correct size for your setup.)
Wire up the split charge device as per instructions - enjoy theextra power!
I have 2x 500+ CCA 12v batteries in my RR, & it does my needs a plenty!!
Hope that is helpful to you!
Old Sep 3, 2007 | 08:01 PM
kjj0506's Avatar
I meant add it to the vehicle in place of the factory Lucas unit ( my fault for not being clear ). I was hoping someone had some tricks or tips for the actual wiring of the alternator i.e. : larger wire here , a capacitor there , "do this-but not that" kind of advice....... but thanks for the input anyway.
Cheers and welcome to the forum.
BTW its all done - New hand fabricated bracket , and all .... works great !
roverwoody
Jan 28, 2014 09:46 AM
grandkodiak
May 13, 2012 05:29 PM
roverwoody
Oct 27, 2009 03:06 PM
roverwoody
Oct 31, 2008 11:03 AM
roverwoody
Oct 28, 2008 10:43 PM
