Another abs/tc?
Old Jun 14, 2010 | 08:49 AM
rtonder's Avatar
I managed to get by without bleeding. I filled the accumulator while it was upside down with fluid, and topped off the fitting where it screws in as well. I folded up some aluminum foil to end up with a strip the size of a tongue depressor, then held it over the accumulator opening while I inverted it. I then slid it on to the pump without letting more than a drop or so out. Mostly luck, and being careful not to tear/drag any foil into the system.
Old Jun 14, 2010 | 12:49 PM
bentonrover's Avatar
Hey wilson96rr where is the plug on the abs pump? Hose or wire? Also check the wheel sensors again(rear). Fronts dont seem to come out. Will a leaky seal around the hubs affect the abs/tc lights? My rear driver and front pass seems to be leaking a diff fluid. Just thought I ask
Old Jun 14, 2010 | 06:11 PM
wilson96rr's Avatar
The plug on the pump is a wire connector. If the little retaining wire clip has been lost, it could have come loose. On mine, yes a leaky wheel bearing did seem to trigger the tc/abs light and sometimes activate the abs during normal braking. The best I can figure is that the gear oil may be leaking through the seal around the wheel speed sensor.
Old Jun 15, 2010 | 08:04 AM
Was thinking the same thing about the wheel sensor. Thanks again
caymandrew
May 2, 2013 06:25 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
whatmeworry?
Aug 1, 2009 08:23 AM
tsuami1
Sep 27, 2007 10:51 PM
