Auto Headlights for '04 RR HSE
Old Apr 11, 2008 | 08:57 AM
alsuch's Avatar
Default Auto Headlights for '04 RR HSE
Not sure if all '04 models were as scantly optioned as mine, but I don't even have an "Auto" headlight setting on my selector switch. I've got a sensor on the dash, but apparently that was installed as common practice on all of them. I do have daytime running lights, which I could really care less about. Has anyone ever pulled off an auto headlight switch conversion on this model. Dealer tells me it's not practical.
Old Apr 12, 2008 | 09:12 PM
roverguy7's Avatar
Default RE: Auto Headlights for '04 RR HSE
you do not have the sensor. that is a sun-load sensor for the a/c. its was not an option until 05, and then standard, aside from westminsters. and no, do not try it.
[/align]
Old Apr 12, 2008 | 10:41 PM
alsuch's Avatar
Well, that being the case, is there any practical means for me togather & install the required compnents resulting in auto headlights in my'04 RR? Even my wife's '04 Jag has autoheadlights.
Old Apr 12, 2008 | 11:08 PM
roverguy7's Avatar
you will at least need a new windshield, for a 05my fitted with a light sensor, and a switch for a 05my too. im not sure if the wiring is there or if you need a new Light Check Module or not, either way on the LCM, it will need to be coded/recoded at your local dealership
[/align]
Old Apr 14, 2008 | 12:09 AM
Mpowered's Avatar
3rd Gear
This non auto headlight situation was driving me crazy. I have a 04 RR and just got the dealer to program the daytime running lights option. Front and rear lights are on as soon as the ignition is turned on and lights go out after the car is turned off. Problem solved.
Old Apr 16, 2008 | 05:53 PM
4.4Range's Avatar
Roverguy7 is right. We got jacked on our 04's. If i knew more about the 04's then I would've bought the 05's. Btw, do I have to go to the stealership to have them program DRL or is that something I can do myself? How much isit?I'm not sure if I want them though...
Old Apr 16, 2008 | 08:23 PM
roverguy7's Avatar
dealership. its part of the ZCS, your vehicle configuration
[/align]
black06lr3
Aug 24, 2010 09:52 PM
Tom Sederburg
Sep 21, 2009 01:53 PM
europartspros
Mar 16, 2009 10:32 PM
1porsche
Oct 5, 2008 04:25 PM
Street Wolf
Sep 27, 2008 08:58 AM
