Best Coolant on 02 RR Orange stuff or the ole Green antifreeze?
from 95 to 99 the P38 has a "GEMS" management system which used green coolant and from 99 to 02 the P38 has the "BOSCH" engine management system which used orange coolant.
That might apply to RROJ's RR and not mine though.
the trick is to take off the upper hose and fill up the engine from there and then open the bleed screw and the cap and pour it in the bottle till all the air is gone from the bleed screw.
Thank you LRScott! That sounds like the secret that will save my engine the 02 from any damage. I will relay this to the mechanic when he does in case he is not aware already.
"the trick is to take off the upper hose and fill up the engine from there and then open the bleed screw and the cap and pour it in the bottle till all the air is gone from the bleed screw."
LRScott, what about lifting the front bumper 6-12 inches I guess to drain every drop out. Do you do this or heard of it working? I have heard of it and it makes perfect sense due to all the gullies and crevices antifreeze can hide in. I would like your opinion on the matter.
Thanks always!
RROJ
Thanks always!
RROJ
Thanks always!
RROJ
Thanks always!
RROJ
Thanks always!
Thanks always!
Hmmm. OK. I can see flushing the system with the regular water until it it is all clear but then when its time to fill it with antifreeze is there any harm of filling it with just pure antifreeze and not the 50/50 mix?
Sorry for all the detailed questions. I have let my other cars just be handled by the mechanic, but with a Range Rover I don't want to do ANYTHING that could end up costing me the demise of my RR.
If you take it to a shop locally that deals with LRs they should be able to help you and do a good job. You will want to fill it with concentrated anti-freeze until the water coming out of the drain plug is of the same color as the 50/50 pre-dilluted mix. And YES it you will cause harm if you fill the system with pure anti-freeze. If you want the green stuff, just tell them you want the entire system flushed and replaced with the green inorganic coolant.
so all you people know who are reading this older thread... the ole green stuff when put in an engine that requires the orange stuff can eat through the gaskets faster... also so you know IT IS CORROSIVE TO ALUMINUM ENGINES I don't understand why people need to change stuff that isn't ment to be changed... it's the same price at autozone as the green stuff maybe 2 dollars more and made for your vehicle... also the GEMS calls for dexcool btw, don't know what manual you are reading.... no disrespect to anyone just callin shenanigans....
