Blend Motor help
Old Jul 10, 2012 | 12:47 PM
dfiring's Avatar
4th Gear
Default Blend Motor help
I have a 2001 RR and have installed a rebuilt set of blend motors, I still have the dash off. The blend motors seem to work but I still have the book light on and the air is still blowing hot on one side and cold on the other. The light on the control is not on but I can see the display is working, the light did work when I took the control unit out. Need help on how to check or set the blend motors to work before putting the dash back on. Help.
Old Jul 10, 2012 | 11:43 PM
krazzz's Avatar
A 2011 Rover would still be under warranty. How did they go bad so soon and why aren't you making the dealer fix this?
Old Jul 11, 2012 | 07:30 AM
dfiring's Avatar
4th Gear
sorry it is a 2001, but thanks
Old Jul 11, 2012 | 06:17 PM
Rovin4life's Avatar
make sure they are working and make sure the wires are installed correctly in the connector.
Old Jul 12, 2012 | 09:34 AM
dfiring's Avatar
4th Gear
The wiring is correct as best as I can tell from the install inforamtion I looked at on line. My questions is about testing the units, how do I test them and know what to expect? I seem to have control of the air movment but the blending of air is still off, one side is hot and one is cold, this is opposite of what I had when I replaced them. I still have the book on the control unit so I guess they are not working correctly? More suggestions please.
dezlpower
Oct 11, 2011 09:35 PM
04BluDisco
Jul 11, 2011 11:58 AM
dezlpower
May 30, 2009 12:04 PM
pdv83
Nov 20, 2007 12:34 PM
deejax
Jul 5, 2006 10:28 PM
